{"name":"Routeur Solaire","description":"Le site du Routeur ;-)","url":"https:\/\/routeursolaire.eu","home":"https:\/\/routeursolaire.eu","gmt_offset":2,"timezone_string":"Europe\/Paris","page_for_posts":0,"page_on_front":29,"show_on_front":"page","namespaces":["oembed\/1.0","asgaros-forum\/v1","kadence-starter-library\/v1","post-smtp\/v1","post-smtp\/v2","psd\/v1","kb-mailerlite\/v1","kb-getresponse\/v1","kb-fluentcrm\/v1","kbp\/v1","kb-lottieanimation\/v1","kb-vector\/v1","kb-design-library\/v1","kb-image-picker\/v1","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/routeursolaire.eu\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"Le format oEmbed \u00e0 utiliser.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"La largeur maximale du contenu embarqu\u00e9 en pixels.","type":"integer","default":600,"required":false},"maxheight":{"description":"La hauteur maximale du contenu embarqu\u00e9 oEmbed en pixels.","type":"integer","required":false},"discover":{"description":"D\u00e9termine s\u2019il faut ou non effectuer une requ\u00eate de d\u00e9couverte oEmbed vers d\u2019autres fournisseurs non autoris\u00e9s.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/oembed\/1.0\/proxy"}]}},"\/asgaros-forum\/v1":{"namespace":"asgaros-forum\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"asgaros-forum\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/asgaros-forum\/v1"}]}},"\/asgaros-forum\/v1\/reaction\/(?P<post_id>\\d+)\/(?P<reaction>[a-zA-Z0-9-]+)":{"namespace":"asgaros-forum\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/asgaros-forum\/v1\/suggestions\/mentioning\/(?P<term>[a-zA-Z0-9-]+)":{"namespace":"asgaros-forum\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/kadence-starter-library\/v1":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kadence-starter-library\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1"}]}},"\/kadence-starter-library\/v1\/starter-help-docs":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/starter-help-docs"}]}},"\/kadence-starter-library\/v1\/handle_event":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"event_label":{"description":"The Event Label","type":"string","required":false},"event_data":{"description":"The Event Data","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/handle_event"}]}},"\/kadence-starter-library\/v1\/get":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get"}]}},"\/kadence-starter-library\/v1\/ai-base":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/ai-base"}]}},"\/kadence-starter-library\/v1\/get-all-local-ai":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get-all-local-ai"}]}},"\/kadence-starter-library\/v1\/get-all-ai":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get-all-ai"}]}},"\/kadence-starter-library\/v1\/remove-content":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/remove-content"}]}},"\/kadence-starter-library\/v1\/install-plugins":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-plugins"}]}},"\/kadence-starter-library\/v1\/install-plugin":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-plugin"}]}},"\/kadence-starter-library\/v1\/install-pages":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-pages"}]}},"\/kadence-starter-library\/v1\/process-pages":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/process-pages"}]}},"\/kadence-starter-library\/v1\/install-posts":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-posts"}]}},"\/kadence-starter-library\/v1\/get-posts":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get-posts"}]}},"\/kadence-starter-library\/v1\/update-pages":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/update-pages"}]}},"\/kadence-starter-library\/v1\/get-products":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get-products"}]}},"\/kadence-starter-library\/v1\/install-products":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-products"}]}},"\/kadence-starter-library\/v1\/get-events":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get-events"}]}},"\/kadence-starter-library\/v1\/install-events":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-events"}]}},"\/kadence-starter-library\/v1\/install-course":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-course"}]}},"\/kadence-starter-library\/v1\/install-donation-form":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-donation-form"}]}},"\/kadence-starter-library\/v1\/install-block-cpt":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-block-cpt"}]}},"\/kadence-starter-library\/v1\/install-settings":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-settings"}]}},"\/kadence-starter-library\/v1\/install-navigation":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-navigation"}]}},"\/kadence-starter-library\/v1\/install-widgets":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/install-widgets"}]}},"\/kadence-starter-library\/v1\/get_remaining_credits":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_remaining_credits"}]}},"\/kadence-starter-library\/v1\/get_auth_data":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_auth_data"}]}},"\/kadence-starter-library\/v1\/get_initial_jobs":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_initial_jobs"}]}},"\/kadence-starter-library\/v1\/has_initial_jobs":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/has_initial_jobs"}]}},"\/kadence-starter-library\/v1\/get_remaining_jobs":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_remaining_jobs"}]}},"\/kadence-starter-library\/v1\/get_local_contexts":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_local_contexts"}]}},"\/kadence-starter-library\/v1\/get_images":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_images"}]}},"\/kadence-starter-library\/v1\/get_image_collections":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_image_collections"}]}},"\/kadence-starter-library\/v1\/get_search_query":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_search_query"}]}},"\/kadence-starter-library\/v1\/get_verticals":{"namespace":"kadence-starter-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_verticals"}]}},"\/kadence-starter-library\/v1\/get_keywords":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/get_keywords"}]}},"\/kadence-starter-library\/v1\/process_images":{"namespace":"kadence-starter-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"The requested ai context.","type":"string","required":false},"page":{"description":"Import Page.","type":"string","required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"The requested library.","type":"string","required":false},"library_url":{"description":"The requested library URL.","type":"string","required":false},"force_reload":{"description":"Force a refresh of the context.","type":"boolean","default":false,"required":false},"key":{"description":"Library Key.","type":"string","required":false},"api_key":{"description":"Kadence License Key.","type":"string","required":false},"api_email":{"description":"Kadence License Email.","type":"string","required":false},"product_id":{"description":"Kadence License Product ID.","type":"string","required":false},"plugins":{"description":"Import Plugins","type":"array","items":{"type":"string"},"required":false},"plugin":{"description":"Import Plugin","type":"string","required":false},"industry":{"description":"The selected Industry","type":"string","required":false},"image_type":{"description":"The Image type to return","type":"string","required":false},"industries":{"description":"The industries to return","type":"array","required":false},"image_sizes":{"description":"The Image type to return","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kadence-starter-library\/v1\/process_images"}]}},"\/post-smtp\/v1":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-smtp\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v1"}]}},"\/post-smtp\/v1\/connect-app":{"namespace":"post-smtp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v1\/connect-app"}]}},"\/post-smtp\/v1\/get-logs":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v1\/get-logs"}]}},"\/post-smtp\/v1\/disconnect-site":{"namespace":"post-smtp\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v1\/disconnect-site"}]}},"\/post-smtp\/v1\/get-log":{"namespace":"post-smtp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v1\/get-log"}]}},"\/post-smtp\/v1\/resend-email":{"namespace":"post-smtp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v1\/resend-email"}]}},"\/post-smtp\/v2":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"post-smtp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v2"}]}},"\/post-smtp\/v2\/get-logs":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v2\/get-logs"}]}},"\/post-smtp\/v2\/validate-license":{"namespace":"post-smtp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/post-smtp\/v2\/validate-license"}]}},"\/psd\/v1":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"psd\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1"}]}},"\/psd\/v1\/get-logs":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/get-logs"}]}},"\/psd\/v1\/get-details":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/get-details"}]}},"\/psd\/v1\/resend-email":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/resend-email"}]}},"\/psd\/v1\/email-count":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/email-count"}]}},"\/psd\/v1\/minimize-maximize-ad":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/minimize-maximize-ad"}]}},"\/psd\/v1\/get-failed-logs":{"namespace":"psd\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/get-failed-logs"}]}},"\/psd\/v1\/open-notification":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/open-notification"}]}},"\/psd\/v1\/remove-notification":{"namespace":"psd\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/psd\/v1\/remove-notification"}]}},"\/kb-mailerlite\/v1":{"namespace":"kb-mailerlite\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-mailerlite\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-mailerlite\/v1"}]}},"\/kb-mailerlite\/v1\/get":{"namespace":"kb-mailerlite\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"apikey":{"description":"La cl\u00e9 d\u2019API pour le compte Mailerlite.","type":"string","required":false},"endpoint":{"description":"Point de terminaison actionnable pour l\u2019appel \u00e0 l\u2019API.","type":"string","required":false},"queryargs":{"description":"Arguments de requ\u00eate pour l\u2019url.","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-mailerlite\/v1\/get"}]}},"\/kb-getresponse\/v1":{"namespace":"kb-getresponse\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-getresponse\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-getresponse\/v1"}]}},"\/kb-getresponse\/v1\/get":{"namespace":"kb-getresponse\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"endpoint":{"description":"Point de terminaison actionnable pour l\u2019appel \u00e0 l\u2019API.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-getresponse\/v1\/get"}]}},"\/kb-fluentcrm\/v1":{"namespace":"kb-fluentcrm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-fluentcrm\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-fluentcrm\/v1"}]}},"\/kb-fluentcrm\/v1\/get":{"namespace":"kb-fluentcrm\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"endpoint":{"description":"Point de terminaison actionnable pour l\u2019appel \u00e0 l\u2019API.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-fluentcrm\/v1\/get"}]}},"\/kbp\/v1":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kbp\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kbp\/v1"}]}},"\/kbp\/v1\/post-query":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre de r\u00e9sultats \u00e0 renvoyer.","type":"number","default":25,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"type":{"description":"Limite le r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un type de publication sp\u00e9cifique.","type":"string","required":false},"include":{"description":"Inclure les publications par ID.","type":"array","required":false},"query":{"description":"D\u00e9finir le type de requ\u00eate.","type":"string","required":false},"order":{"description":"D\u00e9finir l\u2019ordre des requ\u00eates.","type":"string","required":false},"order_by":{"description":"D\u00e9finir l\u2019ordre de la requ\u00eate.","type":"string","required":false},"allow_sticky":{"description":"Autoriser \u00e9pingl\u00e9 dans la requ\u00eate.","type":"boolean","required":false},"exclude":{"description":"Exclure cat\u00e9gorie.","type":"string","required":false},"offset":{"description":"Nombre d\u2019\u00e9l\u00e9ments \u00e0 d\u00e9caler dans la requ\u00eate.","type":"number","default":0,"required":false},"post_id":{"description":"ID de la publication courante.","type":"string","required":false},"custom_tax":{"description":"V\u00e9rifier si l\u2019on utilise une taxonomie personnalis\u00e9e","type":"boolean","required":false},"tax_type":{"description":"D\u00e9finir l\u2019ordre de la requ\u00eate.","type":"string","required":false},"category":{"description":"Inclure les cat\u00e9gories d\u2019articles.","type":"string","required":false},"tags":{"description":"Inclure les \u00e9tiquettes d\u2019articles.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kbp\/v1\/post-query"}]}},"\/kbp\/v1\/taxonomies-select":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page de r\u00e9sultats \u00e0 retourner.","type":"number","default":1,"required":false},"per_page":{"description":"Nombre de r\u00e9sultats \u00e0 renvoyer.","type":"number","default":25,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"source":{"description":"La source du contenu.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kbp\/v1\/taxonomies-select"}]}},"\/kbp\/v1\/term-select":{"namespace":"kbp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page de r\u00e9sultats \u00e0 retourner.","type":"number","default":1,"required":false},"per_page":{"description":"Nombre de r\u00e9sultats \u00e0 renvoyer.","type":"number","default":25,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"source":{"description":"La source du contenu.","type":"string","default":"","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kbp\/v1\/term-select"}]}},"\/kb-lottieanimation\/v1":{"namespace":"kb-lottieanimation\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-lottieanimation\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-lottieanimation\/v1"}]}},"\/kb-lottieanimation\/v1\/animations\/(?P<id>[\\a-zA-Z0-9]+)":{"namespace":"kb-lottieanimation\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/kb-lottieanimation\/v1\/animations":{"namespace":"kb-lottieanimation\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-lottieanimation\/v1\/animations"}]}},"\/kb-vector\/v1":{"namespace":"kb-vector\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-vector\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-vector\/v1"}]}},"\/kb-vector\/v1\/vectors":{"namespace":"kb-vector\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-vector\/v1\/vectors"}]}},"\/kb-design-library\/v1":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-design-library\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1"}]}},"\/kb-design-library\/v1\/get":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get"}]}},"\/kb-design-library\/v1\/get_all_items":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_all_items"}]}},"\/kb-design-library\/v1\/get-all-ai":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get-all-ai"}]}},"\/kb-design-library\/v1\/get_remaining_jobs":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_remaining_jobs"}]}},"\/kb-design-library\/v1\/get_library":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_library"}]}},"\/kb-design-library\/v1\/get_library_categories":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_library_categories"}]}},"\/kb-design-library\/v1\/get_connection":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_connection"}]}},"\/kb-design-library\/v1\/get_local_contexts":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_local_contexts"}]}},"\/kb-design-library\/v1\/get_verticals":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_verticals"}]}},"\/kb-design-library\/v1\/get_keywords":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_keywords"}]}},"\/kb-design-library\/v1\/get_initial_jobs":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_initial_jobs"}]}},"\/kb-design-library\/v1\/get_search_query":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_search_query"}]}},"\/kb-design-library\/v1\/get_images":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_images"}]}},"\/kb-design-library\/v1\/get_image_collections":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_image_collections"}]}},"\/kb-design-library\/v1\/get_pattern_content":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_pattern_content"}]}},"\/kb-design-library\/v1\/process_pattern":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/process_pattern"}]}},"\/kb-design-library\/v1\/process_images":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/process_images"}]}},"\/kb-design-library\/v1\/get_remaining_credits":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/get_remaining_credits"}]}},"\/kb-design-library\/v1\/reset":{"namespace":"kb-design-library\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte de l\u2019ai demand\u00e9.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"library":{"description":"La biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"library_url":{"description":"L'URL de la biblioth\u00e8que demand\u00e9e.","type":"string","required":false},"force_reload":{"description":"Forcer le rafra\u00eechissement du contexte.","type":"boolean","default":false,"required":false},"key":{"description":"Cl\u00e9 de biblioth\u00e8que.","type":"string","required":false},"api_key":{"description":"Cl\u00e9 de la licence Kadence.","type":"string","required":false},"api_email":{"description":"E-mail de la licence Kadence.","type":"string","required":false},"product_id":{"description":"Licence Kadence ID du produit.","type":"string","required":false},"pattern_type":{"description":"Type de composition","type":"string","required":false},"pattern_style":{"description":"Style de composition","type":"string","required":false},"pattern_id":{"description":"ID de la composition","type":"string","required":false},"industry":{"description":"Le secteur d\u2019activit\u00e9 s\u00e9lectionn\u00e9","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"industries":{"description":"Le secteur d\u2019activit\u00e9 retourn\u00e9","type":"array","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false},"meta":{"description":"The meta to return","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/reset"}]}},"\/kb-image-picker\/v1":{"namespace":"kb-image-picker\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"kb-image-picker\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-image-picker\/v1"}]}},"\/kb-image-picker\/v1\/process_images":{"namespace":"kb-image-picker\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"image_type":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"string","required":false},"image_sizes":{"description":"Le type d\u2019image \u00e0 renvoyer","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-image-picker\/v1\/process_images"}]}},"\/kb-design-library\/v1\/handle_event":{"namespace":"kb-design-library\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"event_label":{"description":"Le libell\u00e9 de l\u2019\u00e9v\u00e9nement","type":"string","required":false},"event_data":{"description":"Les donn\u00e9es de l\u2019\u00e9v\u00e9nement","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/kb-design-library\/v1\/handle_event"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments qui sont \u00e9pingl\u00e9s.","type":"boolean","required":false},"ignore_sticky":{"description":"Ignorer les publications \u00e9pingl\u00e9es ou non.","type":"boolean","default":true,"required":false},"format":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments auxquels un ou plusieurs formats sont assign\u00e9s.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limite le jeu de r\u00e9sultats aux fichiers joints d\u2018un type de m\u00e9dia particulier ou de types de m\u00e9dias particuliers.","type":"array","items":{"type":"string","enum":["model","application","text","image","video","audio"]},"required":false},"mime_type":{"default":null,"description":"Limite le jeu de r\u00e9sultats aux fichiers joints d\u2018un type de MIME particulier ou de types de MIME particuliers.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique du fichier joint.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL vers le fichier image modifi\u00e9.","type":"string","format":"uri","required":true},"modifiers":{"description":"Tableau des modifications d\u2019images.","type":"array","minItems":1,"items":{"description":"Modification d\u2019image.","type":"object","required":["type","args"],"oneOf":[{"title":"Retourner","properties":{"type":{"description":"Type de retournement.","type":"string","enum":["flip"]},"args":{"description":"Inverser les arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Sens de retournement.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"D\u00e9termine s\u2019il faut retourner dans le sens horizontal.","type":"boolean"},"vertical":{"description":"D\u00e9termine s\u2019il faut retourner dans le sens vertical.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Type de rotation.","type":"string","enum":["rotate"]},"args":{"description":"Arguments de rotation.","type":"object","required":["angle"],"properties":{"angle":{"description":"Angle de rotation dans le sens horaire en degr\u00e9s.","type":"number"}}}}},{"title":"Recadrer","properties":{"type":{"description":"Type de recadrage.","type":"string","enum":["crop"]},"args":{"description":"Arguments de recadrage.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Position horizontale \u00e0 partir de la gauche pour commencer le recadrage en pourcentage de la largeur de l\u2019image.","type":"number"},"top":{"description":"En pourcentage de l\u2019image, la position verticale \u00e0 partir du haut \u00e0 laquelle commencer le recadrage de l\u2019image.","type":"number"},"width":{"description":"Largeur du recadrage en pourcentage de la largeur de l\u2019image.","type":"number"},"height":{"description":"Hauteur du recadrage en pourcentage de la hauteur de l\u2019image.","type":"number"}}}}}]},"required":false},"rotation":{"description":"La valeur en degr\u00e9s de la rotation de l\u2019image dans le sens des aiguilles d\u2019une montre. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"En pourcentage de l\u2019image, la position X \u00e0 laquelle commencer le recadrage de l\u2019image. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"En pourcentage de l\u2019image, la position Y \u00e0 laquelle commencer le recadrage de l\u2019image. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"En pourcentage de l\u2019image, la largeur \u00e0 laquelle il faut recadrer l\u2019image. Obsol\u00e8te\u00a0: Utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"En pourcentage de l\u2019image, la hauteur \u00e0 laquelle il faut recadrer l\u2019image. Obsol\u00e8te\u00a0: Utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie menus.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie menus.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"default":1,"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"default":0,"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limiter \u00e0 l\u2019ID de publication sp\u00e9cifi\u00e9.","type":"integer","required":false},"area":{"description":"Limite \u00e0 la zone de l\u2019\u00e9l\u00e9ment de mod\u00e8le sp\u00e9cifi\u00e9.","type":"string","required":false},"post_type":{"description":"Type de publication pour lequel obtenir les mod\u00e8les.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"default":"","description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"default":"publish","description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Le slug du mod\u00e8le doit r\u00e9cup\u00e9rer l\u2019alternative pour","type":"string","required":true},"is_custom":{"description":"Indique si un mod\u00e8le est personnalis\u00e9 ou fait partie de la hi\u00e9rarchie des mod\u00e8les.","type":"boolean","required":false},"template_prefix":{"description":"Le pr\u00e9fixe de mod\u00e8le pour le mod\u00e8le cr\u00e9\u00e9. Ceci est utilis\u00e9 pour extraire le type de mod\u00e8le principal, p.\u00a0ex.\u00a0dans \u00ab\u00a0taxonomy-books\u00a0\u00bb, cela extrait \u00ab\u00a0taxonomy\u00a0\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limiter \u00e0 l\u2019ID de publication sp\u00e9cifi\u00e9.","type":"integer","required":false},"area":{"description":"Limite \u00e0 la zone de l\u2019\u00e9l\u00e9ment de mod\u00e8le sp\u00e9cifi\u00e9.","type":"string","required":false},"post_type":{"description":"Type de publication pour lequel obtenir les mod\u00e8les.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"default":"","description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"default":"publish","description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Le slug du mod\u00e8le doit r\u00e9cup\u00e9rer l\u2019alternative pour","type":"string","required":true},"is_custom":{"description":"Indique si un mod\u00e8le est personnalis\u00e9 ou fait partie de la hi\u00e9rarchie des mod\u00e8les.","type":"boolean","required":false},"template_prefix":{"description":"Le pr\u00e9fixe de mod\u00e8le pour le mod\u00e8le cr\u00e9\u00e9. Ceci est utilis\u00e9 pour extraire le type de mod\u00e8le principal, p.\u00a0ex.\u00a0dans \u00ab\u00a0taxonomy-books\u00a0\u00bb, cela extrait \u00ab\u00a0taxonomy\u00a0\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la r\u00e9vision des styles globaux.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision de styles globaux.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L\u2018identifiant du th\u00e8me","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L\u2018identifiant du th\u00e8me","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID de la configuration de styles globaux.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Styles globaux.","type":["object"],"required":false},"settings":{"description":"R\u00e9glages globaux.","type":["object"],"required":false},"title":{"description":"Titre de la variation de styles globaux.","type":["object","string"],"properties":{"raw":{"description":"Titre de la variation de styles globaux, tel qu\u2019il existe en base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"d\u00e9claration font-family dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"d\u00e9claration font-family dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"D\u00e9claration font-face dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"id":{"description":"Identifiant unique de la police de caract\u00e8res.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"id":{"description":"Identifiant unique de la police de caract\u00e8res.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/bp3d-model-viewer":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/bp3d-model-viewer"}]}},"\/wp\/v2\/bp3d-model-viewer\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/bp3d-model-viewer\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/bp3d-model-viewer\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_form":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_form_fields":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"uniqueID":{"type":"string"},"name":{"type":"string"},"label":{"type":"string"},"type":{"type":"string"}},"additionalProperties":false}},"_kad_form_email":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","fromEmail":"","fromName":"","replyTo":"email_field","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_mailerlite":{"type":"object","title":"","description":"","default":{"group":[],"map":[]},"properties":{"group":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_fluentcrm":{"type":"object","title":"","description":"","default":{"lists":[],"tags":[],"map":[],"doubleOptin":false},"properties":{"lists":{"type":"array"},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_sendinblue":{"type":"object","title":"","description":"","default":{"lists":[],"map":[]},"properties":{"lists":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_mailchimp":{"type":"object","title":"","description":"","default":{"list":[],"map":[],"groups":[],"tags":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}},"groups":{"type":"array"},"tags":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_getresponse":{"type":"object","title":"","description":"","default":{"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_convertkit":{"type":"object","title":"","description":"","default":{"form":[],"sequence":[],"tags":[],"map":[]},"properties":{"form":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"sequence":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_activecampaign":{"type":"object","title":"","description":"","default":{"list":[],"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_modified_in_kf_plugin":{"type":"boolean","title":"","description":"","default":false},"_kad_form_browserValidation":{"type":"boolean","title":"","description":"","default":true},"_kad_form_enableAnalytics":{"type":"boolean","title":"","description":"","default":false},"_kad_form_redirect":{"type":"string","title":"","description":"","default":""},"_kad_form_submitHide":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptcha":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptchaVersion":{"type":"string","title":"","description":"","default":"v3"},"_kad_form_webhook":{"type":"object","title":"","description":"","default":{"url":"","map":[]},"properties":{"url":{"type":"string"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_autoEmail":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","message":"","fromEmail":"","fromName":"","replyTo":"","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"message":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_entry":{"type":"object","title":"","description":"","default":{"userIP":true,"userDevice":true},"properties":{"userIP":{"type":"boolean"},"userDevice":{"type":"boolean"}},"additionalProperties":false},"_kad_form_fieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_tabletFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_mobileFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_fieldBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px","properties":"px"},"_kad_form_description":{"type":"string","title":"","description":"","default":""},"_kad_form_fieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messages":{"type":"object","title":"","description":"","default":{"success":"","error":"","required":"","invalid":"","recaptchaerror":"","preError":""},"properties":{"success":{"type":"string"},"error":{"type":"string"},"required":{"type":"string"},"invalid":{"type":"string"},"recaptchaerror":{"type":"string"},"preError":{"type":"string"}},"additionalProperties":false},"_kad_form_inputFont":{"type":"object","title":"","description":"","default":{"color":"","colorActive":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"colorActive":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_style":{"type":"object","title":"","description":"","default":{"showRequired":true,"size":"standard","padding":["","","",""],"tabletPadding":["","","",""],"mobilePadding":["","","",""],"paddingUnit":"px","requiredColor":"","background":"","backgroundActive":"","borderActive":"","placeholderColor":"","gradient":"","gradientActive":"","backgroundType":"normal","backgroundActiveType":"normal","boxShadow":[false,"#000000",0.2,1,1,2,0,false],"boxShadowActive":[false,"#000000",0.4,2,2,3,0,false],"gap":["","",""],"gapUnit":"px","labelStyle":"normal","basicStyles":true,"isDark":false},"properties":{"showRequired":{"type":"boolean"},"size":{"type":"string"},"padding":{"type":"array"},"tabletPadding":{"type":"array"},"mobilePadding":{"type":"array"},"paddingUnit":{"type":"string"},"requiredColor":{"type":"string"},"background":{"type":"string"},"backgroundActive":{"type":"string"},"borderActive":{"type":"string"},"placeholderColor":{"type":"string"},"gradient":{"type":"string"},"gradientActive":{"type":"string"},"backgroundType":{"type":"string"},"backgroundActiveType":{"type":"string"},"boxShadow":{"type":"array"},"boxShadowActive":{"type":"array"},"gap":{"type":"array"},"gapUnit":{"type":"string"},"labelStyle":{"type":"string"},"basicStyles":{"type":"boolean"},"isDark":{"type":"boolean"}},"additionalProperties":false},"_kad_form_background":{"type":"object","title":"","description":"","default":{"background":"","gradient":"","backgroundType":"normal"},"properties":{"background":{"type":"string"},"gradient":{"type":"string"},"backgroundType":{"type":"string"}},"additionalProperties":false},"_kad_form_labelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_radioLabelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_form_helpFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_messageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_anchor":{"type":"string","title":"","description":"","default":""},"_kad_form_className":{"type":"string","title":"","description":"","default":""},"_kad_form_actions":{"type":"array","title":"","description":"","default":["email"],"items":{"type":"string"}},"_kad_form_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tableMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messagePaddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageMarginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageColor":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackground":{"type":"string","title":"","description":"","default":""},"_kad_form_messageColorError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackgroundError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageFont":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizetype":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadgoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizetype":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadgoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_form_maxWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_maxWidth":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_form_importId":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_form"}]}},"\/wp\/v2\/kadence_form\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_form_fields":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"uniqueID":{"type":"string"},"name":{"type":"string"},"label":{"type":"string"},"type":{"type":"string"}},"additionalProperties":false}},"_kad_form_email":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","fromEmail":"","fromName":"","replyTo":"email_field","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_mailerlite":{"type":"object","title":"","description":"","default":{"group":[],"map":[]},"properties":{"group":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_fluentcrm":{"type":"object","title":"","description":"","default":{"lists":[],"tags":[],"map":[],"doubleOptin":false},"properties":{"lists":{"type":"array"},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_sendinblue":{"type":"object","title":"","description":"","default":{"lists":[],"map":[]},"properties":{"lists":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_mailchimp":{"type":"object","title":"","description":"","default":{"list":[],"map":[],"groups":[],"tags":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}},"groups":{"type":"array"},"tags":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_getresponse":{"type":"object","title":"","description":"","default":{"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_convertkit":{"type":"object","title":"","description":"","default":{"form":[],"sequence":[],"tags":[],"map":[]},"properties":{"form":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"sequence":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_activecampaign":{"type":"object","title":"","description":"","default":{"list":[],"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_modified_in_kf_plugin":{"type":"boolean","title":"","description":"","default":false},"_kad_form_browserValidation":{"type":"boolean","title":"","description":"","default":true},"_kad_form_enableAnalytics":{"type":"boolean","title":"","description":"","default":false},"_kad_form_redirect":{"type":"string","title":"","description":"","default":""},"_kad_form_submitHide":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptcha":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptchaVersion":{"type":"string","title":"","description":"","default":"v3"},"_kad_form_webhook":{"type":"object","title":"","description":"","default":{"url":"","map":[]},"properties":{"url":{"type":"string"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_autoEmail":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","message":"","fromEmail":"","fromName":"","replyTo":"","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"message":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_entry":{"type":"object","title":"","description":"","default":{"userIP":true,"userDevice":true},"properties":{"userIP":{"type":"boolean"},"userDevice":{"type":"boolean"}},"additionalProperties":false},"_kad_form_fieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_tabletFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_mobileFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_fieldBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px","properties":"px"},"_kad_form_description":{"type":"string","title":"","description":"","default":""},"_kad_form_fieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messages":{"type":"object","title":"","description":"","default":{"success":"","error":"","required":"","invalid":"","recaptchaerror":"","preError":""},"properties":{"success":{"type":"string"},"error":{"type":"string"},"required":{"type":"string"},"invalid":{"type":"string"},"recaptchaerror":{"type":"string"},"preError":{"type":"string"}},"additionalProperties":false},"_kad_form_inputFont":{"type":"object","title":"","description":"","default":{"color":"","colorActive":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"colorActive":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_style":{"type":"object","title":"","description":"","default":{"showRequired":true,"size":"standard","padding":["","","",""],"tabletPadding":["","","",""],"mobilePadding":["","","",""],"paddingUnit":"px","requiredColor":"","background":"","backgroundActive":"","borderActive":"","placeholderColor":"","gradient":"","gradientActive":"","backgroundType":"normal","backgroundActiveType":"normal","boxShadow":[false,"#000000",0.2,1,1,2,0,false],"boxShadowActive":[false,"#000000",0.4,2,2,3,0,false],"gap":["","",""],"gapUnit":"px","labelStyle":"normal","basicStyles":true,"isDark":false},"properties":{"showRequired":{"type":"boolean"},"size":{"type":"string"},"padding":{"type":"array"},"tabletPadding":{"type":"array"},"mobilePadding":{"type":"array"},"paddingUnit":{"type":"string"},"requiredColor":{"type":"string"},"background":{"type":"string"},"backgroundActive":{"type":"string"},"borderActive":{"type":"string"},"placeholderColor":{"type":"string"},"gradient":{"type":"string"},"gradientActive":{"type":"string"},"backgroundType":{"type":"string"},"backgroundActiveType":{"type":"string"},"boxShadow":{"type":"array"},"boxShadowActive":{"type":"array"},"gap":{"type":"array"},"gapUnit":{"type":"string"},"labelStyle":{"type":"string"},"basicStyles":{"type":"boolean"},"isDark":{"type":"boolean"}},"additionalProperties":false},"_kad_form_background":{"type":"object","title":"","description":"","default":{"background":"","gradient":"","backgroundType":"normal"},"properties":{"background":{"type":"string"},"gradient":{"type":"string"},"backgroundType":{"type":"string"}},"additionalProperties":false},"_kad_form_labelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_radioLabelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_form_helpFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_messageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_anchor":{"type":"string","title":"","description":"","default":""},"_kad_form_className":{"type":"string","title":"","description":"","default":""},"_kad_form_actions":{"type":"array","title":"","description":"","default":["email"],"items":{"type":"string"}},"_kad_form_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tableMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messagePaddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageMarginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageColor":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackground":{"type":"string","title":"","description":"","default":""},"_kad_form_messageColorError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackgroundError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageFont":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizetype":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadgoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizetype":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadgoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_form_maxWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_maxWidth":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_form_importId":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/kadence_form\/auto-draft":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_form\/auto-draft"}]}},"\/wp\/v2\/kadence_form\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_form\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/kadence_form\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_form_fields":{"type":"array","title":"","description":"","default":[],"items":{"type":"object","properties":{"uniqueID":{"type":"string"},"name":{"type":"string"},"label":{"type":"string"},"type":{"type":"string"}},"additionalProperties":false}},"_kad_form_email":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","fromEmail":"","fromName":"","replyTo":"email_field","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_mailerlite":{"type":"object","title":"","description":"","default":{"group":[],"map":[]},"properties":{"group":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_fluentcrm":{"type":"object","title":"","description":"","default":{"lists":[],"tags":[],"map":[],"doubleOptin":false},"properties":{"lists":{"type":"array"},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_sendinblue":{"type":"object","title":"","description":"","default":{"lists":[],"map":[]},"properties":{"lists":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_mailchimp":{"type":"object","title":"","description":"","default":{"list":[],"map":[],"groups":[],"tags":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"map":{"type":"object","additionalProperties":{"type":"string"}},"groups":{"type":"array"},"tags":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_getresponse":{"type":"object","title":"","description":"","default":{"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_convertkit":{"type":"object","title":"","description":"","default":{"form":[],"sequence":[],"tags":[],"map":[]},"properties":{"form":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"sequence":{"type":"object","properties":{"value":{"type":"number"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_activecampaign":{"type":"object","title":"","description":"","default":{"list":[],"automation":[],"tags":[],"map":[],"listMulti":[],"doubleOptin":false},"properties":{"list":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"automation":{"type":"object","properties":{"value":{"type":"string"},"label":{"type":"string"}},"additionalProperties":false},"tags":{"type":"array"},"map":{"type":"object","additionalProperties":{"type":"string"}},"listMulti":{"type":"array"},"doubleOptin":{"type":"boolean"}},"additionalProperties":false},"_kad_form_modified_in_kf_plugin":{"type":"boolean","title":"","description":"","default":false},"_kad_form_browserValidation":{"type":"boolean","title":"","description":"","default":true},"_kad_form_enableAnalytics":{"type":"boolean","title":"","description":"","default":false},"_kad_form_redirect":{"type":"string","title":"","description":"","default":""},"_kad_form_submitHide":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptcha":{"type":"boolean","title":"","description":"","default":false},"_kad_form_recaptchaVersion":{"type":"string","title":"","description":"","default":"v3"},"_kad_form_webhook":{"type":"object","title":"","description":"","default":{"url":"","map":[]},"properties":{"url":{"type":"string"},"map":{"type":"object","additionalProperties":{"type":"string"}}},"additionalProperties":false},"_kad_form_autoEmail":{"type":"object","title":"","description":"","default":{"emailTo":"","subject":"","message":"","fromEmail":"","fromName":"","replyTo":"","cc":"","bcc":"","html":true},"properties":{"emailTo":{"type":"string"},"subject":{"type":"string"},"message":{"type":"string"},"fromEmail":{"type":"string"},"fromName":{"type":"string"},"replyTo":{"type":"string"},"cc":{"type":"string"},"bcc":{"type":"string"},"html":{"type":"boolean"}},"additionalProperties":false},"_kad_form_entry":{"type":"object","title":"","description":"","default":{"userIP":true,"userDevice":true},"properties":{"userIP":{"type":"boolean"},"userDevice":{"type":"boolean"}},"additionalProperties":false},"_kad_form_fieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_tabletFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_mobileFieldBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"properties":["","","",""]},"_kad_form_fieldBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px","properties":"px"},"_kad_form_description":{"type":"string","title":"","description":"","default":""},"_kad_form_fieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileFieldBorderStyle":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messages":{"type":"object","title":"","description":"","default":{"success":"","error":"","required":"","invalid":"","recaptchaerror":"","preError":""},"properties":{"success":{"type":"string"},"error":{"type":"string"},"required":{"type":"string"},"invalid":{"type":"string"},"recaptchaerror":{"type":"string"},"preError":{"type":"string"}},"additionalProperties":false},"_kad_form_inputFont":{"type":"object","title":"","description":"","default":{"color":"","colorActive":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"colorActive":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_style":{"type":"object","title":"","description":"","default":{"showRequired":true,"size":"standard","padding":["","","",""],"tabletPadding":["","","",""],"mobilePadding":["","","",""],"paddingUnit":"px","requiredColor":"","background":"","backgroundActive":"","borderActive":"","placeholderColor":"","gradient":"","gradientActive":"","backgroundType":"normal","backgroundActiveType":"normal","boxShadow":[false,"#000000",0.2,1,1,2,0,false],"boxShadowActive":[false,"#000000",0.4,2,2,3,0,false],"gap":["","",""],"gapUnit":"px","labelStyle":"normal","basicStyles":true,"isDark":false},"properties":{"showRequired":{"type":"boolean"},"size":{"type":"string"},"padding":{"type":"array"},"tabletPadding":{"type":"array"},"mobilePadding":{"type":"array"},"paddingUnit":{"type":"string"},"requiredColor":{"type":"string"},"background":{"type":"string"},"backgroundActive":{"type":"string"},"borderActive":{"type":"string"},"placeholderColor":{"type":"string"},"gradient":{"type":"string"},"gradientActive":{"type":"string"},"backgroundType":{"type":"string"},"backgroundActiveType":{"type":"string"},"boxShadow":{"type":"array"},"boxShadowActive":{"type":"array"},"gap":{"type":"array"},"gapUnit":{"type":"string"},"labelStyle":{"type":"string"},"basicStyles":{"type":"boolean"},"isDark":{"type":"boolean"}},"additionalProperties":false},"_kad_form_background":{"type":"object","title":"","description":"","default":{"background":"","gradient":"","backgroundType":"normal"},"properties":{"background":{"type":"string"},"gradient":{"type":"string"},"backgroundType":{"type":"string"}},"additionalProperties":false},"_kad_form_labelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_radioLabelFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_form_helpFont":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true,"padding":["","","",""],"margin":["","","",""]},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"},"padding":{"type":"array"},"margin":{"type":"array"}},"additionalProperties":false},"_kad_form_messageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderSuccess":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_messageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_tabletMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_mobileMessageBorderError":{"type":"object","title":"","description":"","default":{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":""},"properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false},"_kad_form_anchor":{"type":"string","title":"","description":"","default":""},"_kad_form_className":{"type":"string","title":"","description":"","default":""},"_kad_form_actions":{"type":"array","title":"","description":"","default":["email"],"items":{"type":"string"}},"_kad_form_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageBorderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tableMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessagePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messagePaddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_tabletMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_mobileMessageMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_form_messageMarginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_messageColor":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackground":{"type":"string","title":"","description":"","default":""},"_kad_form_messageColorError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageBackgroundError":{"type":"string","title":"","description":"","default":""},"_kad_form_messageFont":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizetype":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadgoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizetype":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadgoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_form_maxWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_form_maxWidth":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_form_importId":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_form\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_navigation_description":{"type":"string","title":"","description":"","default":""},"_kad_navigation_anchor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_className":{"type":"string","title":"","description":"","default":""},"_kad_navigation_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_orientation":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacing":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_style":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_horizontalLayout":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_horizontalLayoutTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalLayoutMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGrid":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFill":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_stretchFillTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFillMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_parentActive":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_collapseSubMenus":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusTablet":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusMobile":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_parentTogglesMenus":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_background":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_divider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_typography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_descriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownDescriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownWidth":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownVerticalSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_dropdownHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownDescriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_descriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_descriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_dropdownDescriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownShadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.1,"spread":0,"blur":13,"hOffset":0,"vOffset":2,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownReveal":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownBorder":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_backgroundType":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeHover":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeActive":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundGradient":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHover":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActive":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHover":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActive":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitHover":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitActive":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowHover":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowActive":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_linkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_enableScrollSpy":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_scrollSpyOffsetManual":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffset":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetMobile":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_navigation"}]}},"\/wp\/v2\/kadence_navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_navigation_description":{"type":"string","title":"","description":"","default":""},"_kad_navigation_anchor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_className":{"type":"string","title":"","description":"","default":""},"_kad_navigation_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_orientation":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacing":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_style":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_horizontalLayout":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_horizontalLayoutTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalLayoutMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGrid":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFill":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_stretchFillTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFillMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_parentActive":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_collapseSubMenus":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusTablet":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusMobile":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_parentTogglesMenus":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_background":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_divider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_typography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_descriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownDescriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownWidth":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownVerticalSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_dropdownHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownDescriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_descriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_descriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_dropdownDescriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownShadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.1,"spread":0,"blur":13,"hOffset":0,"vOffset":2,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownReveal":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownBorder":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_backgroundType":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeHover":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeActive":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundGradient":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHover":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActive":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHover":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActive":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitHover":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitActive":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowHover":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowActive":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_linkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_enableScrollSpy":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_scrollSpyOffsetManual":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffset":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetMobile":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/kadence_navigation\/auto-draft":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_navigation\/auto-draft"}]}},"\/wp\/v2\/kadence_navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/kadence_navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_navigation_description":{"type":"string","title":"","description":"","default":""},"_kad_navigation_anchor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_className":{"type":"string","title":"","description":"","default":""},"_kad_navigation_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdown":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_paddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletPaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobilePaddingDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_paddingDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_marginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_tabletMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_mobileMarginDropdownLink":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_marginDropdownLinkUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_orientation":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_orientationMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacing":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_spacingMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_style":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_styleMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_spacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_horizontalLayout":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_horizontalLayoutTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalLayoutMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGrid":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_horizontalGridMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFill":{"type":"string","title":"","description":"","default":"standard"},"_kad_navigation_stretchFillTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_stretchFillMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_parentActive":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentActiveMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_collapseSubMenus":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusTablet":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_collapseSubMenusMobile":{"type":"boolean","title":"","description":"","default":true},"_kad_navigation_parentTogglesMenus":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusTablet":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_parentTogglesMenusMobile":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_background":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdown":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundDropdownActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparent":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundTransparentActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkColorStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundSticky":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundStickyActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColor":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorHoverMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionColorActiveMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_divider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_transparentDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDivider":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerTablet":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_stickyDividerMobile":{"type":"array","title":"","description":"","default":[{"top":["","",""],"right":["","",""],"bottom":["","",""],"left":["","",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_typography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_descriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownDescriptionTypography":{"type":"array","title":"","description":"","default":[{"size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true}],"items":{"type":"object","properties":{"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownWidth":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownWidthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownVerticalSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownVerticalSpacingUnit":{"type":"string","title":"","description":"","default":"em"},"_kad_navigation_dropdownHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_dropdownDescriptionSpacing":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionSpacingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_descriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_descriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_descriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioning":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_dropdownDescriptionPositioningTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownDescriptionPositioningMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownShadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.1,"spread":0,"blur":13,"hOffset":0,"vOffset":2,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_dropdownReveal":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownRevealMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownBorder":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_dropdownBorderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_navigation_dropdownBorderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_backgroundType":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeHover":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundTypeActive":{"type":"string","title":"","description":"","default":"normal"},"_kad_navigation_backgroundGradient":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientHover":{"type":"string","title":"","description":"","default":""},"_kad_navigation_backgroundGradientActive":{"type":"string","title":"","description":"","default":""},"_kad_navigation_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHover":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderHoverMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActive":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderActiveMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_navigation_borderRadius":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHover":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusHoverMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActive":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveTablet":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusActiveMobile":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_navigation_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitHover":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_borderRadiusUnitActive":{"type":"string","title":"","description":"","default":"px"},"_kad_navigation_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowHover":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_shadowActive":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":1,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_navigation_linkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_linkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignment":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_dropdownLinkHorizontalAlignmentMobile":{"type":"string","title":"","description":"","default":""},"_kad_navigation_enableScrollSpy":{"type":"boolean","title":"","description":"","default":false},"_kad_navigation_scrollSpyOffsetManual":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffset":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetTablet":{"type":"string","title":"","description":"","default":""},"_kad_navigation_scrollSpyOffsetMobile":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_header":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_header_description":{"type":"string","title":"","description":"","default":""},"_kad_header_typography":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_header_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderTransparent":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusTransparent":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderSticky":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusSticky":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_background":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundTransparent":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundSticky":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_anchor":{"type":"string","title":"","description":"","default":""},"_kad_header_className":{"type":"string","title":"","description":"","default":""},"_kad_header_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_header_linkHoverColor":{"type":"string","title":"","description":"","default":""},"_kad_header_height":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_heightUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_width":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_widthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_isSticky":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparent":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_autoTransparentSpacing":{"type":"boolean","title":"","description":"","default":false},"_kad_header_stickySection":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMain":{"type":"boolean","title":"","description":"","default":false},"_kad_header_shrinkMainHeight":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_revealScrollUp":{"type":"boolean","title":"","description":"","default":false},"_kad_header_inheritPostTransparent":{"type":"boolean","title":"","description":"","default":true},"_kad_header_disableTransparentOverrides":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"_kad_header_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":0,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_header_headerTag":{"type":"string","title":"","description":"","default":""},"_kad_header_mobileBreakpoint":{"type":"number","title":"","description":"","default":0},"_kad_header_pro_backdropFilterType":{"type":"string","title":"","description":"","default":""},"_kad_header_pro_backdropFilterSize":{"type":"number","title":"","description":"","default":1},"_kad_header_pro_backdropFilterString":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_header"}]}},"\/wp\/v2\/kadence_header\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_header_description":{"type":"string","title":"","description":"","default":""},"_kad_header_typography":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_header_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderTransparent":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusTransparent":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderSticky":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusSticky":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_background":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundTransparent":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundSticky":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_anchor":{"type":"string","title":"","description":"","default":""},"_kad_header_className":{"type":"string","title":"","description":"","default":""},"_kad_header_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_header_linkHoverColor":{"type":"string","title":"","description":"","default":""},"_kad_header_height":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_heightUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_width":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_widthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_isSticky":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparent":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_autoTransparentSpacing":{"type":"boolean","title":"","description":"","default":false},"_kad_header_stickySection":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMain":{"type":"boolean","title":"","description":"","default":false},"_kad_header_shrinkMainHeight":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_revealScrollUp":{"type":"boolean","title":"","description":"","default":false},"_kad_header_inheritPostTransparent":{"type":"boolean","title":"","description":"","default":true},"_kad_header_disableTransparentOverrides":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"_kad_header_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":0,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_header_headerTag":{"type":"string","title":"","description":"","default":""},"_kad_header_mobileBreakpoint":{"type":"number","title":"","description":"","default":0},"_kad_header_pro_backdropFilterType":{"type":"string","title":"","description":"","default":""},"_kad_header_pro_backdropFilterSize":{"type":"number","title":"","description":"","default":1},"_kad_header_pro_backdropFilterString":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/kadence_header\/auto-draft":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_header\/auto-draft"}]}},"\/wp\/v2\/kadence_header\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_header\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/kadence_header\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_kadence_starter_templates_imported_post":{"type":"boolean","title":"","description":"","default":false},"_kad_post_transparent":{"type":"string","title":"","description":"","default":""},"_kad_post_title":{"type":"string","title":"","description":"","default":""},"_kad_post_layout":{"type":"string","title":"","description":"","default":""},"_kad_post_sidebar_id":{"type":"string","title":"","description":"","default":""},"_kad_post_content_style":{"type":"string","title":"","description":"","default":""},"_kad_post_vertical_padding":{"type":"string","title":"","description":"","default":""},"_kad_post_feature":{"type":"string","title":"","description":"","default":""},"_kad_post_feature_position":{"type":"string","title":"","description":"","default":""},"_kad_post_header":{"type":"boolean","title":"","description":"","default":false},"_kad_post_footer":{"type":"boolean","title":"","description":"","default":false},"_kad_post_classname":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""},"_kad_header_description":{"type":"string","title":"","description":"","default":""},"_kad_header_typography":{"type":"object","title":"","description":"","default":{"color":"","size":["","",""],"sizeType":"px","lineHeight":["","",""],"lineType":"","letterSpacing":["","",""],"letterType":"px","textTransform":"","family":"","google":false,"style":"","weight":"","variant":"","subset":"","loadGoogle":true},"properties":{"color":{"type":"string"},"size":{"type":"array"},"sizeType":{"type":"string"},"lineHeight":{"type":"array"},"lineType":{"type":"string"},"letterSpacing":{"type":"array"},"letterType":{"type":"string"},"textTransform":{"type":"string"},"family":{"type":"string"},"google":{"type":"boolean"},"style":{"type":"string"},"weight":{"type":"string"},"variant":{"type":"string"},"subset":{"type":"string"},"loadGoogle":{"type":"boolean"}},"additionalProperties":false},"_kad_header_border":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadius":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderTransparent":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderTransparentMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusTransparent":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusTransparentUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_borderSticky":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyTablet":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderStickyMobile":{"type":"array","title":"","description":"","default":[{"top":["","solid",""],"right":["","solid",""],"bottom":["","solid",""],"left":["","solid",""],"unit":"px"}],"items":{"type":"object","properties":{"top":{"type":"array"},"right":{"type":"array"},"bottom":{"type":"array"},"left":{"type":"array"},"unit":{"type":"string"}},"additionalProperties":false}},"_kad_header_borderRadiusSticky":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyTablet":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyMobile":{"type":"array","title":"","description":"","default":[0,0,0,0],"items":{"type":"integer"}},"_kad_header_borderRadiusStickyUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_background":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundTransparent":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_backgroundSticky":{"type":"object","title":"","description":"","default":{"color":"","image":"","imageID":"","position":"center center","size":"cover","repeat":"no-repeat","attachment":"scroll","type":"normal","gradient":""},"properties":{"color":{"type":"string"},"image":{"type":"string"},"imageID":{"type":"string"},"position":{"type":"string"},"size":{"type":"string"},"repeat":{"type":"string"},"attachment":{"type":"string"},"type":{"type":"string"},"gradient":{"type":"string"}},"additionalProperties":false},"_kad_header_anchor":{"type":"string","title":"","description":"","default":""},"_kad_header_className":{"type":"string","title":"","description":"","default":""},"_kad_header_padding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletPadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobilePadding":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_paddingUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_margin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_tabletMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_mobileMargin":{"type":"array","title":"","description":"","default":["","","",""],"items":{"type":"string"}},"_kad_header_marginUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_linkColor":{"type":"string","title":"","description":"","default":""},"_kad_header_linkHoverColor":{"type":"string","title":"","description":"","default":""},"_kad_header_height":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_heightUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_width":{"type":"array","title":"","description":"","default":["","",""],"items":{"type":"string"}},"_kad_header_widthUnit":{"type":"string","title":"","description":"","default":"px"},"_kad_header_isSticky":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isStickyMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparent":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_isTransparentMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_autoTransparentSpacing":{"type":"boolean","title":"","description":"","default":false},"_kad_header_stickySection":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_stickySectionMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMain":{"type":"boolean","title":"","description":"","default":false},"_kad_header_shrinkMainHeight":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightTablet":{"type":"string","title":"","description":"","default":""},"_kad_header_shrinkMainHeightMobile":{"type":"string","title":"","description":"","default":""},"_kad_header_revealScrollUp":{"type":"boolean","title":"","description":"","default":false},"_kad_header_inheritPostTransparent":{"type":"boolean","title":"","description":"","default":true},"_kad_header_disableTransparentOverrides":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"_kad_header_shadow":{"type":"array","title":"","description":"","default":[{"enable":false,"color":"#000000","opacity":0.2,"spread":0,"blur":2,"hOffset":0,"vOffset":1,"inset":false}],"items":{"type":"object","properties":{"enable":{"type":"boolean"},"color":{"type":"string"},"opacity":{"type":"number"},"spread":{"type":"number"},"blur":{"type":"number"},"hOffset":{"type":"number"},"vOffset":{"type":"number"},"inset":{"type":"boolean"}},"additionalProperties":false}},"_kad_header_headerTag":{"type":"string","title":"","description":"","default":""},"_kad_header_mobileBreakpoint":{"type":"number","title":"","description":"","default":0},"_kad_header_pro_backdropFilterType":{"type":"string","title":"","description":"","default":""},"_kad_header_pro_backdropFilterSize":{"type":"number","title":"","description":"","default":1},"_kad_header_pro_backdropFilterString":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_header\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_lottie":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_lottie"}]}},"\/wp\/v2\/kadence_lottie\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_lottie\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/kadence_vector":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/kadence_vector"}]}},"\/wp\/v2\/kadence_vector\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/kadence_vector\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Un identificateur alphanum\u00e9rique pour le type de publication.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Un identificateur alphanum\u00e9rique pour l\u2019\u00e9tat.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limiter les r\u00e9sultats aux taxonomies associ\u00e9es un type de publication sp\u00e9cifique.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Un identificateur alphanum\u00e9rique pour la taxonomie.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false},"locations":{"description":"Les emplacements assign\u00e9s au menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ajouter automatiquement les pages de premier niveau \u00e0 ce menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false},"locations":{"description":"Les emplacements assign\u00e9s au menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ajouter automatiquement les pages de premier niveau \u00e0 ce menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attributs de compte.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limiter le jeu de r\u00e9sultats aux comptes correspondant \u00e0 au moins une capacit\u00e9 sp\u00e9cifique fournie. Accepte une liste CSV ou une capacit\u00e9 unique.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limiter le jeu de r\u00e9sultats aux comptes consid\u00e9r\u00e9s comme auteurs ou autrices.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limiter les r\u00e9sultats aux comptes qui ont mis en ligne des publications.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","bp3d-model-viewer":"bp3d-model-viewer","kadence_form":"kadence_form","kadence_navigation":"kadence_navigation","kadence_header":"kadence_header","kadence_lottie":"kadence_lottie","kadence_vector":"kadence_vector"}},"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nom de connexion pour le compte.","type":"string","required":true},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":true},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","nl_NL"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":true},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"username":{"description":"Nom de connexion pour le compte.","type":"string","required":false},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":false},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","nl_NL"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les comptes ne prennent pas en charge la suppression forc\u00e9e.","required":false},"reassign":{"type":"integer","description":"R\u00e9affectez les publications et les liens du compte supprim\u00e9 \u00e0 cet ID de compte.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nom de connexion pour le compte.","type":"string","required":false},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":false},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","nl_NL"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les comptes ne prennent pas en charge la suppression forc\u00e9e.","required":false},"reassign":{"type":"integer","description":"R\u00e9affectez les publications et les liens du compte supprim\u00e9 \u00e0 cet ID de compte.","required":true}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Un UUID fourni par l\u2019application pour l\u2019identifier de mani\u00e8re unique. Il est recommand\u00e9 d\u2019utiliser un UUID v5 avec l\u2019URL ou l\u2019espace de noms DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Le nom du mot de passe de l\u2019application.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Un UUID fourni par l\u2019application pour l\u2019identifier de mani\u00e8re unique. Il est recommand\u00e9 d\u2019utiliser un UUID v5 avec l\u2019URL ou l\u2019espace de noms DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Le nom du mot de passe de l\u2019application.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s apr\u00e8s une date donn\u00e9e et conforme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s aux ID de compte sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les commentaires assign\u00e9s aux ID des comptes sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limiter le jeu de r\u00e9sultats \u00e0 une adresse e-mail d\u2019auteur ou d\u2019autrice sp\u00e9cifique. N\u00e9cessite les droits correspondants.","format":"email","type":"string","required":false},"before":{"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s avant une date donn\u00e9e et conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de commentaire.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limiter le jeu de r\u00e9sultats aux commentaires ayant un ID parent sp\u00e9cifique.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID parents sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 des ID de publications sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique. N\u00e9cessite les droits correspondants.","type":"string","required":false},"type":{"default":"comment","description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un type sp\u00e9cifique. N\u00e9cessite des droits sp\u00e9cifiques.","type":"string","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"L\u2019ID de l\u2019objet <code>user<\/code>, si l\u2019auteur ou l\u2019autrice \u00e9tait un compte.","type":"integer","required":false},"author_email":{"description":"Adresse e-mail de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"email","required":false},"author_ip":{"description":"Adresse IP de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"ip","required":false},"author_name":{"description":"Nom affich\u00e9 pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"author_url":{"description":"URL pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agent utilisateur pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"content":{"description":"Le contenu pour le commentaire.","type":"object","properties":{"raw":{"description":"Contenu pour le commentaire, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour le commentaire, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"L\u2019ID du parent du commentaire.","type":"integer","required":false},"post":{"default":0,"description":"L\u2019ID de l\u2019objet publication associ\u00e9.","type":"integer","required":false},"status":{"description":"\u00c9tat du commentaire.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u00c9tat de r\u00e9solution de la note","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Mot de passe de la publication parente du commentaire (si la publication est prot\u00e9g\u00e9e par un mot de passe).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"author":{"description":"L\u2019ID de l\u2019objet <code>user<\/code>, si l\u2019auteur ou l\u2019autrice \u00e9tait un compte.","type":"integer","required":false},"author_email":{"description":"Adresse e-mail de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"email","required":false},"author_ip":{"description":"Adresse IP de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"ip","required":false},"author_name":{"description":"Nom affich\u00e9 pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"author_url":{"description":"URL pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agent utilisateur pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"content":{"description":"Le contenu pour le commentaire.","type":"object","properties":{"raw":{"description":"Contenu pour le commentaire, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour le commentaire, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"L\u2019ID du parent du commentaire.","type":"integer","required":false},"post":{"description":"L\u2019ID de l\u2019objet publication associ\u00e9.","type":"integer","required":false},"status":{"description":"\u00c9tat du commentaire.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u00c9tat de r\u00e9solution de la note","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false},"password":{"description":"Mot de passe de la publication parente du commentaire (si la publication est prot\u00e9g\u00e9e par un mot de passe).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"type":{"default":"post","description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un type d\u2019objet.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un ou plusieurs sous-types d\u2019objet.","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nom unique enregistr\u00e9 de ce bloc.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attributs pour le bloc.","type":"object","default":[],"required":false},"post_id":{"description":"ID de ce contenu\/contexte.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nom du bloc.","type":"string","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"kadence_site_assist_tasks":{"title":"","description":"Site Assist Tasks","type":"object","properties":{"language":{"type":"boolean","description":"The current status of the language tasks."},"logo":{"type":"boolean","description":"The current status of the logo tasks."},"timezone":{"type":"boolean","description":"The current status of the timezone tasks."},"colors":{"type":"boolean","description":"The current status of the color tasks."},"header":{"type":"boolean","description":"The current status of the header tasks."},"footer":{"type":"boolean","description":"The current status of the footer tasks."},"typography":{"type":"boolean","description":"The current status of the typography tasks."},"buttons":{"type":"boolean","description":"The current status of the button tasks."},"posts":{"type":"boolean","description":"The current status of the post tasks."},"archive":{"type":"boolean","description":"The current status of the archive tasks."},"email-test":{"type":"boolean","description":"The current status of the email test tasks."}},"additionalProperties":false,"required":false},"kadence_blocks_config_blocks":{"title":"","description":"Par d\u00e9fauts Config Kadence Block","type":"string","required":false},"kadence_blocks_settings_blocks":{"title":"","description":"Configurer les r\u00e9glages de visibilt\u00e9 de Kadence blocks","type":"string","required":false},"kadence_blocks_settings":{"title":"","description":"R\u00e9glages de Config Kadence Block","type":"string","required":false},"kadence_blocks_prophecy":{"title":"","description":"Configurer Kadence Block Prophecy AI","type":"string","required":false},"kadence_blocks_colors":{"title":"","description":"Config Palette de couleurs Kadence blocks","type":"string","required":false},"kadence_blocks_global":{"title":"","description":"Configurer les r\u00e9glages globaux Kadence blocks","type":"string","required":false},"kadence_blocks_recaptcha_site_key":{"title":"","description":"Cl\u00e9 du site Google reCaptcha","type":"string","required":false},"kadence_blocks_recaptcha_secret_key":{"title":"","description":"Cl\u00e9 secr\u00e8te Google reCaptcha","type":"string","required":false},"kadence_blocks_recaptcha_language":{"title":"","description":"Langue de Google reCaptcha","type":"string","required":false},"kadence_blocks_turnstile_site_key":{"title":"","description":"Cl\u00e9 de site Cloudflare Turnstile","type":"string","required":false},"kadence_blocks_turnstile_secret_key":{"title":"","description":"Cl\u00e9 secr\u00e8te de Cloudflare Turnstile","type":"string","required":false},"kadence_blocks_hcaptcha_site_key":{"title":"","description":"cl\u00e9 de site hCaptcha Turnstile","type":"string","required":false},"kadence_blocks_hcaptcha_secret_key":{"title":"","description":"cl\u00e9 secr\u00e8te hCaptcha","type":"string","required":false},"kadence_blocks_mailerlite_api":{"title":"","description":"Cl\u00e9 API MailerLite","type":"string","required":false},"kadence_blocks_google_maps_api":{"title":"","description":"Cl\u00e9 API Google Maps","type":"string","required":false},"kadence_blocks_cloud":{"title":"","description":"Config Kadence Blocks Cloud","type":"string","required":false},"kadence_blocks_header_notice_dismissed":{"title":"","description":"Is Kadence header notice dismissed","type":"boolean","required":false},"kadence_blocks_wire_subscribe":{"title":"","description":"S\u2019abonner \u00e0 la biblioth\u00e8que Wireframe","type":"boolean","required":false},"kadence_blocks_convertkit_api":{"title":"","description":"Cl\u00e9 API de ConvertKit","type":"string","required":false},"kadence_blocks_activecampaign_api_key":{"title":"","description":"Cl\u00e9 API de ConvertKit","type":"string","required":false},"kadence_blocks_activecampaign_api_base":{"title":"","description":"Cl\u00e9 API de ConvertKit","type":"string","required":false},"kadence_blocks_header_popover_tutorial_complete":{"title":"","description":"Mark the Header popover tutorial Complete","type":"boolean","required":false},"kadence_theme_config":{"title":"","description":"Config modules Kadence","type":"string","required":false},"kadence_starter_templates_config":{"title":"","description":"Configurer les Mod\u00e8les de D\u00e9marrage Kadence","type":"string","required":false},"title":{"title":"Titre","description":"Titre du site.","type":"string","required":false},"description":{"title":"Slogan","description":"Slogan du site.","type":"string","required":false},"url":{"title":"","description":"URL du site.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Cette adresse est utilis\u00e9e \u00e0 des fins d\u2019administration, comme les notifications de nouveaux comptes.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Une ville dans le m\u00eame fuseau horaire que le v\u00f4tre.","type":"string","required":false},"date_format":{"title":"","description":"Un format de date commun pour tous les r\u00e9glages de dates.","type":"string","required":false},"time_format":{"title":"","description":"Un format d\u2019heure commun pour tous les r\u00e9glages d\u2019heures.","type":"string","required":false},"start_of_week":{"title":"","description":"Le num\u00e9ro du jour de la semaine \u00e0 laquelle la semaine devrait commencer.","type":"integer","required":false},"language":{"title":"","description":"Code local de l\u2019installation WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Convertir les \u00e9motic\u00f4nes, comme :-) et :-P, en images lors de l\u2019affichage.","type":"boolean","required":false},"default_category":{"title":"","description":"Cat\u00e9gorie d\u2019article par d\u00e9faut.","type":"integer","required":false},"default_post_format":{"title":"","description":"Format d\u2019article par d\u00e9faut.","type":"string","required":false},"posts_per_page":{"title":"Nombre maximum de publications par page","description":"Les pages de blog affichent au maximum.","type":"integer","required":false},"show_on_front":{"title":"Affichage en page d\u2019accueil","description":"Afficher quoi sur la page d\u2019accueil","type":"string","required":false},"page_on_front":{"title":"Page d\u2019accueil","description":"L\u2019ID de la page qui doit \u00eatre affich\u00e9 sur la page d\u2019accueil","type":"integer","required":false},"page_for_posts":{"title":"","description":"L\u2019ID de la page qui affichera les derniers articles","type":"integer","required":false},"default_ping_status":{"title":"","description":"Autoriser les liens de notification d\u2019autres blogs (pings et r\u00e9troliens) sur les nouveaux articles.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Autoriser les commentaires sur les nouvelles publications","description":"Autoriser les gens \u00e0 envoyer des commentaires sur les nouvelles publications.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo du site.","type":"integer","required":false},"site_icon":{"title":"Ic\u00f4ne","description":"Ic\u00f4ne du site.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limiter les r\u00e9sultats aux th\u00e8mes qui poss\u00e8dent un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"La feuille de style du th\u00e8me. Elle identifie le th\u00e8me de mani\u00e8re unique.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"status":{"description":"Limiter les r\u00e9sultats aux extensions ayant l\u2019\u00e9tat sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug sur le r\u00e9pertoire des extensions WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"L\u2019\u00e9tat d\u2019activation de l\u2019extension.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"L\u2019\u00e9tat d\u2019activation de l\u2019extension.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID d\u2019une colonne lat\u00e9rale enregistr\u00e9e","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets imbriqu\u00e9s.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance courante du widget.","type":"object","required":false},"form_data":{"description":"Les donn\u00e9es s\u00e9rialis\u00e9es du formulaire du widget \u00e0 encoder dans les r\u00e9glages de l\u2019instance.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance courante du widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"La colonne lat\u00e9rale pour laquelle renvoyer les widgets.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique du widget.","type":"string","required":false},"id_base":{"description":"Type de widget. Correspond \u00e0 l\u2019ID du point de terminaison widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"La colonne lat\u00e9rale \u00e0 laquelle appartient le widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance du widget, si pris en charge.","type":"object","properties":{"encoded":{"description":"Repr\u00e9sentation des r\u00e9glages de l\u2019instance encod\u00e9e en base64.","type":"string","context":["edit"]},"hash":{"description":"Cl\u00e9 cryptographique hach\u00e9e des r\u00e9glages de l\u2019instance.","type":"string","context":["edit"]},"raw":{"description":"R\u00e9glages de l\u2019instance non encod\u00e9s, si pris en charge.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Donn\u00e9e de formulaire encod\u00e9e dans une URL pour le formulaire de l\u2019administration des widgets. Utilis\u00e9 pour mettre \u00e0 jour un widget qui ne prend pas en charge les instances. En \u00e9criture uniquement.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique du widget.","type":"string","required":false},"id_base":{"description":"Type de widget. Correspond \u00e0 l\u2019ID du point de terminaison widget-types.","type":"string","required":false},"sidebar":{"description":"La colonne lat\u00e9rale \u00e0 laquelle appartient le widget.","type":"string","required":false},"instance":{"description":"R\u00e9glages de l\u2019instance du widget, si pris en charge.","type":"object","properties":{"encoded":{"description":"Repr\u00e9sentation des r\u00e9glages de l\u2019instance encod\u00e9e en base64.","type":"string","context":["edit"]},"hash":{"description":"Cl\u00e9 cryptographique hach\u00e9e des r\u00e9glages de l\u2019instance.","type":"string","context":["edit"]},"raw":{"description":"R\u00e9glages de l\u2019instance non encod\u00e9s, si pris en charge.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Donn\u00e9e de formulaire encod\u00e9e dans une URL pour le formulaire de l\u2019administration des widgets. Utilis\u00e9 pour mettre \u00e0 jour un widget qui ne prend pas en charge les instances. En \u00e9criture uniquement.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Indique s\u2019il faut forcer la suppression du widget ou le d\u00e9placer vers la colonne lat\u00e9rale inactive.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limiter les r\u00e9sultats aux blocs correspondant au terme de recherche.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","minLength":1,"required":false},"category":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 l\u2019identifiant d\u2019une cat\u00e9gorie.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 un identifiant de mot-cl\u00e9.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une composition (slug).","type":"array","required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL \u00e0 traiter.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Un identificateur alphanum\u00e9rique pour l\u2019emplacement de menu.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identifiant unique de la cat\u00e9gorie de fonctionnalit\u00e9s.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Param\u00e8tres d\u2019entr\u00e9e pour l\u2019ex\u00e9cution de cette \u00ab\u00a0ability\u00a0\u00bb.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb d\u2019une cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/routeursolaire.eu\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":78,"site_icon":76,"site_icon_url":"https:\/\/routeursolaire.eu\/wp-content\/uploads\/2022\/05\/cropped-routeur-logo-1.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/media\/78"},{"embeddable":true,"type":"site_icon","href":"https:\/\/routeursolaire.eu\/wp-json\/wp\/v2\/media\/76"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
